Kiwiplan - Multi-Plant Harmonization
What fields and areas that need to be standardize in ESP and MAP.
This section was put together from the aspect if we were going forward either with one MAP database or Multi-MAP databases scenario.
All plants in one ESP database
Here is a list of fields/lookups that need to be standardized in the ESP database
Destination Codes
Styles for Descriptions and print outs
Stacking Patterns shared with MAP parameters
All countries/states/provinces in a separate MAP Database
Here is a list of fields/lookups that need to be standardized all across the MAP databases
Colors
Pallet Types
Top Board Codes
Closure Codes
Strapping Codes
Stacking Patterns shared with ESP
Tab Types
Score Types
Ink Types
10) Tools Types
11) Tool Names when the tool is shared
12) Machine Operations
13) Unit Descriptions
14) Basic Board Codes
15) Downtime Codes
16) Waste Codes
17) Machine numbers
18) BRD-ST, Material Status
19) CORR-FL, Corrugator flutes
20) CSC-BS, Board structure
21) CSC-CC, Coating codes
22) CSC-OS, Order status codes and desc
23) CSC-PC, Paper class
24) GEN-FB, Default waste codes
25) GEN-LT, Label types
26) GEN-QC, Down time categories
27) GEN-UM, Units of measure
28) GEN-WC, Waste code classes
29) PCS-QE, PCS - machine groups
30) PCS-QO, PCS - order status
31) PCS-QR, PCS - run rate units
32) Label Formats
33) Board Code
Board Codes
The image below shows how we would setup board codes to be used in MAP. The ESP sales board code would only be seen in ESP for costing and sale purposes. The plant board code would only be seen on the production side and used to produce the item. Depending on the local plant’s available papers the combination would change at every plant. The producing plant’s combination would be setup in the CSC system to have an upgrade downgrade path to the top board code from sale board code.
NOTE: There is currently a limit to 16 upgrade and downgrade paths.
