Skip to main content
Kiwiplan - KDW Data Warehouse
Introduction
The document assumes that you have the server build with a Kiwiplan environment.
These are things that need to be done on after the installation of KDW.
These instructions may not follow the same folder setup our was installed using the “KDW” site name.
Environment
Add these to the environment to make it easier to navigate to the folders
export KIWIBASE=/KIWI
export KIWI=${KIWI:-/KIWI/site_$PLANTID}
export KBIN=${KBIN:-${KIWIBASE}/services/etl/kdw/current/kiwiplan/bin}
export KLOG=${KLOG:-${KIWIBASE}/services/etl/kdw/current/kiwiplan/log}
export KCONF=${KCONF:-${KIWIBASE}/services/etl/kdw/current/kiwiplan/conf}
Logout and log back in to get the variables and be able to use them
Admin Console prep
You need to add the dashboard to the the pam authentication
cd $KCONF
sudo cp kdw-adminconsole_eample /etc/pam.d/kdw-adminconsole
Database Readiness
Run this to make sure there are no table lock.
USE master;
GO
ALTER DATABASE [kdw_master_datawarehouse]
SET SINGLE_USER
WITH ROLLBACK IMMEDIATE;
GO
ALTER DATABASE [kdw_master_datawarehouse] SET READ_COMMITTED_SNAPSHOT ON;
GO
SET MULTI_USER;
GOUSE master;
GO
ALTER DATABASE [kdw_working_datawarehouse]
SET SINGLE_USER
GO
ALTER DATABASE [kdw_working_datawarehouse] SET READ_COMMITTED_SNAPSHOT ON;
GO
SET MULTI_USER;
GO
MySQL Connector
https://dev.mysql.com/downloads/connector/j/
For 9.80.x revision you must use 5.41 as version 8.x.x do not work.
Extract the file and then copy the .jar to the DIST folder.
[/KIWI/services/etl/kdw/current/kiwiplan/dist]$
mysql-connector-java-5.1.44-bin.jar
Setting Console
cd /opt/kiwi/services/etl/kdw/current/kiwiplan/conf
cp kdw-adminconsole_example /etc/pam.d/kdw-adminconsole
chmod 777 /etc/pam.d/kdw-adminconsole
Extra Executors
To setup extra executors to reduce the time of execution for each system.
You will need to copy the executor properties files to another by adding a numeric value to the name
[/KIWI/services/etl/kdw/current/kiwiplan/conf]$
cp application_executor.properties application_executor1.properties
The new file needs to be edited and this value changed
## KDW executer name
kdw.executor-name=Main_Executor
To the following value
kdw.executor-name=Main_Executor1
Revision 9.8.x
Make sure you un the following.
[/KIWI/services/etl/kdw/current/kiwiplan/bin]$
dwdate_initialization.sh
Restart Script
You can create a restart.sh script with the following
vi restart.sh
Then add this in the file
./stopExecutors.sh
./stopSchedulers.sh
./startSchedulers.sh
sleep 15
./startExecutors.sh
Make the file executable for the system
chmod 777 restart.sh
