Skip to main content
Kiwiplan - Bag of Tricks for ESP and MAP/MES
Agents
Agents
ESP Agent Retry Errors Setup
Agent can be set up to retry errors so that the system reprocesses failed requests.
InfClient/Section/Agent General
Name        Scope  Value
Restart Error Text        whole  Automation error
Maximum Automatic Retry Count For Failed Requests         whole  3
InfClient/Section/Agent Errors To Retry
Name                                                              Scope  Value
Agent exited without completing request      whole  Agent exited
Cannot find matching dockets                        whole  Cannot find matching dockets
changed by another user                                whole  changed by another user
Clipboard                                                        whole  Clipboard
Deadlock                                                         whole  deadlock
Execution canceled                                         whole  Execution canceled
Operation Cancelled                                       whole  Operation canceled
PalletMovement                                             whole  PalletMovement
Updated by another user                               whole  Updated by another user
Application Shortcut Line Options
The 1 equals true and the 0 equals false. You can also use True or False those will also turn these options on or off.
All of these options have the semicolon to separate the option with the True or False
Ex: PrintToFile:1 or PrintToFile:True
KiwiXplor & Agent Options
DBServer:
This is the hostname of the SQL server.
DBName:
This is the DataBase name to use on the SQL server.
DBPassword:
This is to specify a SQL DataBase password to log into SQL server.
DBLogin:
This is to specify a NT/Network SQL DataBase Login to log into SQL server.
NTLogin:
Replaces the Domain user name to the one specified.
Plant:
Is the plant code (from MAP) in GEN/PL
SQLLog:
This enables logging of calls to the SQL DataBase
Width:
Is the width of the ESP window that opens by default
Height:
Is the length of the ESP window that opens by default
Object Log:
Logs object usage in ESP, an interval defined in seconds
HostDebugLevel:
Is the Tcp connection between ESP and the Unix system (aka KIDS) debugging level 0 - 5 (5 = most detailed)
KiwiXplor Options Only
HostName:
This is to change the Linux server
HostDataSet:
This is to access the MAP DataSet that is specified in the KIDSENV file. For more info on this parameter look at the “First Time Installation Guide”.
HostUser:
This is to specify the Unix server login name to log into the MAP DataSet.
HostPassword:
This is to specify the Unix server login password to log into the MAP DataSet.
DBTimeOut:
Is a setting for the amount of time in seconds before the database should give up waiting for a reply from the SQL DataBase.
Agent Options Only (depreciated after 7.80)
AgentNumber:
This is used when more than one Agent has been setup in ESP to handle different types of requests
PrintToFile:
This is used if printing documents to a file instead of physically printing (good for testing).
ShowWord:
This is used if Word is to display the populating of templates as Word documents are printing
Freeze a ESP dataset in time
Freezes your dataset in time. To use this you will have to create a file in the ESPServ folder and call it “profile.ini” and then add the following within the file
[SheetPlant]
StartDateTime=10/30/2014 16:25:25
TimeZone=Eastern Standard Time
LocaleID=1033
[CHH]
StartDateTime=02/10/03 14:45:00
TimeZone=New Zealand Standard Time
LocaleID=5129
Using this option on the properties command line you have to use it like this
profilesection:CHH
Reference https://kall.kiwiplan.co.nz/kall/kiwiplan/issueViewer.do?action=viewIssue&searchId=7&issueId=72725
Example of KiwiXplor Options
KiwiXplor Target Line
 Example of a target:
“K:\Kiwiplan\Kiwiplan\KiwiXplor.exe” HOSTUSER:john HOSTPASSWORD:doe HOSTNAME:192.168.242.129 HOSTDATASET:Cinncinati DBSERVER:172.16.6.16 DBNAME:espbox
 Note: Make sure that there is a space between each of the options e.g.: HOSTUSER:john(space)
Example of Agent Options
Agent Target Line
K:\Kiwiplan\Kiwiplan\EspAgent.exe AgentNumber:3
Tricks & Shortcuts
Main Keys
F4 is a shortcut key used to display a combo field box (drop down box).
Simply click into the field and hit F4.
F5 is a shortcut key used to bring up another window from within the current one you are in.
Simply click into the field (even if it is grayed out) and hit F5
E.g.:     If you are in the Product Design window you can click on the company field, press F5, and another window will open, displaying the company.
F8 is a shortcut key used to bring up special instructions in any Comment or Special Instruction field. These special instructions are stored in the Macro section of the relevant application.
Simply click into the field and hit F8
Alternative Manual Invoice/Credit Parameter
Several of the external Word docs in ESP are designed to allow for multiple templates of the same document. For example, it’s possible to have many different invoices. The standard invoice template is used unless a different template file is specified on the Documentation tab on the Company form for a particular company. This is the same for order confirmations, price lists, dockets etc.
The manual invoice and credit are not set up this way. You cannot attach a different manual invoice template or manual credit template to a customer. However, there are two parameters that allow for the use of alternative template files for manual invoices and credits:
EspClient/Invoicing/ Alternative Manual Invoice Template Formula
EspClient/Invoicing/ Alternative Manual Credit Template Formula
These parameters specify the template to be used for the manual invoice and manual credit using a business rule in the Value field.
Example:
If the parameter has the value:
iif([company.region]="Export", "ExportInvoice", iif([productcode]="Tool", "ServiceInvoice", "ManualInvoice"))
Then:
  • If the region for the company is set to Export, then the ExportInvoice template is used.
  • If the region is not set to Export and the Product code is Tool then the ServiceInvoice template is used.
  • In all other cases, the ManualInvoice template is used.
