Kiwiplan - Box Plant Classic/Refresh To VUE Master Parameters
Master Data Parameters for a Classic Refresh Plant
This is used to know where the parameter take affect in either VUE or Classic
| ReFresh | ||||
| Setup In | ||||
| Classic | VUE | Option | Vue Script | Comments |
| Yes | Material > Material Group > Board Group | |||
| Yes | Configuration > Organization > Score Types | Make sure default in VUE is set but also set CORR-CP & PCS-QB | ||
| Yes | Yes | Configuration > Organization > Score Types & PCS-QB & CORR-CP | Make sure that classic has the default converting score set | |
| Yes | Materials > Flute Types | |||
| Yes | Materials > Material Group > Board Group | |||
| Yes | Materials > Material Groups > Paper Classes | |||
| Yes | Yes | CSC00 > P > CSC > UD | ||
| Yes | Configuration > Downtime > Downtime Classes | |||
| Yes | Yes | Materials > Materials > Shippers & GEN-SN | VUE only needed for COMMS. Classic for everything else | |
| Yes | PCS00 > P > GEN > TB | |||
| Yes | PCS00 > P > GEN > TU | |||
| Yes | Yes | Configuration > Parameters > Manufacturing > COMMS & GEN-UM | ||
| Yes | GEN-UP | Not used in VUE but stored on the unitising table | ||
| Yes | PCS00 > P > GEN > WC | |||
| Yes | INV-SM | Not used in VUE but stored on the shipmethod and job table | ||
| Yes | PCS00 > P > PCS > CC | Yes | ||
| Yes | PCS00 > P > PCS > CE | Yes | ||
| Yes | PCS-CN, GEN-CM, GEN-CN | |||
| Yes | Configuration > Parameters > PCS > Feedback | |||
| Yes | PCS00 > P > PCS > IC | Yes | ||
| Yes | Configuration > Tool > Tool Types & PCS-PD | VUE needs these for tooling but ESP reads classic for type | ||
| Yes | PCS00 > P > PCS > QD | |||
| Yes | PCS00 > P > PCS > QS | |||
| Yes | Configuration > Organization > Machine Groups & PCS-QE | Classic & ESP reads the group description from classic | ||
| Yes | Configuration > Machine > Machine Operations & PCS-QK | |||
| Yes | Configuration > Order > Hold Statuses | |||
| Yes | PCS00 > P > PCS > QP | |||
| Yes | Configuration > Machine > Slot WidthCodes | |||
| Data Fields | ||||
| Yes | Materials > Materials > Papers | |||
| Yes | Materials > Materials > Starch | |||
| Yes | Materials > Materials > Corrugated Boards | |||
| Yes | Materials > Materials > Corrugator Coatings | |||
| Yes | PCS00 > L > D | |||
| Materials > Material Group > Ink Groups | ||||
| Yes | Configuration > Organization > Plant > Stores and invmenu | Only machine in and out feed locations need to be in VUE | ||
| Yes | Yes | Configuration > KDG Templates & lbs00:A | Just code needs to exist in classic, label defined in VUE | |
| Yes | Configuration > Organization > Plant > Machines | |||
| Calendars > Shift Names | ||||
| Calendars > Calendars | ||||
| PICS and ESP | Must enter in ESP and PICS and must match | |||
