Raspberry PI - Uctronics panel setup
This is to setup the panel on the rack mount UCTRONICS raspberry pi holder with SSD drives
You will need to get the following from GitHub
sudo git clone https://github.com/UCTRONICS/SKU_RM0004.git
Compile the download
cd SKU_RM0004
sudo make clean && sudo make
Run this to auto configure
sudo ./deployment_service.sh
Reboot your Pi
sudo reboot
Below Depricated
You will have to modify the following file
sudo nano /boot/config.txt
or
sudo nano /boot/firmware/config.txt
At the end of the file add below the last [ALL] section
dtparam=i2c_arm=on,i2c_arm_baudrate=400000
dtoverlay=gpio-shutdown,gpio_pin=4,active_low=1,gpio_pull=up
Run the following
cd SKU_RM0004
make
Edit the following file:
sudo nano /etc/rc.local
You will need to add the following after the fi and before the exit 0
Once modified should look like this
Run the following:
cd /home/pi/SKU_RM0004
make clean
make
./display &
