Skip to main content
Raspberry Pi - Kiosk
Configure kiosk mode
clear chrome cache
rm -rf ~/.cache/chromium ~/.config/chromium
New one https://reelyactive.github.io/diy/pi-kiosk/
https://github.com/debloper/piosk
Change hostname if not already done
sudo hostnamectl set-hostname ???
sudo reboot
Install the following
sudo apt install xdotool unclutter
Create a kiosk file
sudo nano /home/pi/kiosk.sh
Paste the following in for chromium
#!/bin/bash
xset s noblank
xset s off
xset -dpms
unclutter -idle 0.5 -root &
sed -i 's/"exited_cleanly":false/"exited_cleanly":true/' /home/pi/.config/chromium/Default/Preferences
sed -i 's/"exit_type":"Crashed"/"exit_type":"Normal"/' /home/pi/.config/chromium/Default/Preferences
#/usr/bin/chromium-browser --noerrdialogs --disable-infobars --kiosk https://www.raspberrypi.com/ https://time.is/London &
#/usr/bin/chromium-browser --no-sandbox --window-size=1024,768 --kiosk --window-position=0,0 https://hdrcameras.onling.com:5001/webman/3rdparty/SurveillanceStation/?launchApp=SYNO.SS.App.VideoViewerVue.Instance&SynoToken=W9ZwQIG7NiF1Q &
#/usr/bin/chromium-browser --window-size=1080,720 --kiosk --window-position=0,0 https://www.hammerdownrange.com/lobby/index.php &
/usr/bin/chromium-browser --window-size=1080,720 --kiosk --window-position=0,0 https://www.hammerdownrange.com/lineup/lineup.php &
while true; do
   xdotool keydown ctrl+Tab; xdotool keyup ctrl+Tab;
   sleep 10
done
Paste the following in for firefox
# Disable screen blanking and power management (works on both X11 and Wayland via xwayland compatibility)
xset s noblank
xset s off
xset -dpms
# Hide mouse cursor (unclutter works best on X11; if you're on pure Wayland, see notes below)
# Optional: Clean any crash flags (Firefox is more forgiving, but harmless to keep)
sed -i 's/"exited_cleanly":false/"exited_cleanly":true/' ~/.mozilla/firefox/*.default*/prefs.js 2>/dev/null || true
# Launch Firefox in kiosk mode
# -kiosk          → Fullscreen kiosk (hides UI, prevents exiting easily)
/usr/bin/firefox --kiosk --private-window https://synology.onling.com/webman/3rdparty/SurveillanceStation/login.cgi?SynoToken=nQhMc44EQyoEpeg &
# Optional: Cycle tabs / refresh every 10 seconds (your original behavior)
# If you only have one URL, you can comment this out or change it to a refresh instead
while true; do
    # Send Ctrl+Tab to cycle tabs (if you open multiple tabs)
    sleep 10
done
Make it executable
sudo chmod 777 /home/pi/kiosk.sh
Make a service file to auto startup
sudo nano /lib/systemd/system/kiosk.service
[Unit]
Description=Firefox Kiosk Mode
After=graphical.target
Wants=graphical.target
[Service]
Type=simple
Environment=DISPLAY=:0
ExecStart=/home/pi/kiosk.sh
Restart=always
RestartSec=5
User=pi
WorkingDirectory=/home/pi
[Install]
WantedBy=graphical.target
Make it so it auto starts and start it
sudo systemctl enable kiosk.service
sudo systemctl start kiosk.service
