Dual Garage Door Opener
Using ESPHome
This is code for dual garage door opener and will show red when door is opened
Dashboard
This is built using a
ESP32
and some magnet switches
REED
The REED is only one per door
substitutions:
friendly_name: SFL-GARAGE-001
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
esp32:
board: esp32dev
framework:
type: esp-idf
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
ap:
ssid: "Sfl-Garage-001 Fallback Hotspot"
password: "xxx"
api:
encryption:
key: "xxxxxx"
ota:
- platform: esphome
password: "xxxxx"
logger:
level: ERROR
web_server:
port: 80
bluetooth_proxy:
active: true
captive_portal:
# --- Relays (momentary button press) ---
switch:
- platform: gpio
pin: GPIO25
inverted: true
name: "Door 1 Button"
on_turn_on:
- delay: 500ms
- switch.turn_off: garage_button_1
- platform: gpio
pin: GPIO32
inverted: true
name: "Door 2 Button"
on_turn_on:
- delay: 500ms
- switch.turn_off: garage_button_2
# --- Reed Switches ---
binary_sensor:
- platform: gpio
pin:
number: GPIO05
mode: INPUT_PULLUP
inverted: false
name: "Door 1 Sensor"
device_class: garage_door
icon: "mdi:garage"
filters:
- delayed_on: 100ms
- delayed_off: 100ms
- platform: gpio
pin:
number: GPIO04
mode: INPUT_PULLUP
inverted: false
name: "Door 2 Sensor"
icon: "mdi:garage"
filters:
- delayed_on: 100ms
# --- Garage Door Covers ---
cover:
- platform: template
optimistic: false
lambda: |-
if (id(garage_sensor_1).state) {
return COVER_CLOSED;
} else {
return COVER_OPEN;
open_action:
- switch.turn_on: garage_button_1
close_action:
stop_action:
optimistic: false
lambda: |-
if (id(garage_sensor_2).state) {
} else {
return COVER_OPEN;
open_action:
- switch.turn_on: garage_button_2
close_action:
stop_action:
